T61 vs. AF61, decisions decisions
#76
Originally Posted by KaoticFdR1
I made 452 on a stock ignition at 21psi.....Break up galore and steve lifted on the tune its all visable on the sheet you can see for yourself here.
that looks more like boost creep than breakup.
#77
Originally Posted by D-R Autosports
holes in my story...YOU MUST HAVE HOLES IN YOUR HEAD! i said with the help of a Garrett engineer we were able to come up with a really efficent wheel even though it was kinda of an accident. You must understand that Garrett won't spend the money it cost to create a map for a TURBO THAT ONLY USES A COUPLE OF THIER PARTS ...let alone a person only selling a few per month! ****, THEY ARE NOW IN THE BUSINESS OF PUTTING THE LITTLE GUY OUT OF BUSINESS....JUST ASK THIER WD'S WHOM HAVE BEEN DOING $1.000.000 PER YEAR FOR OVER 15 YEARS . Anyway, only my customers will represent my products... not some naysayer!!!!
now yu're getting all butthurt. do you actually know what this compressor is capable of? it's not "off the shelf"...ok, what is it then? how is it modified?
do you personally have any dyno sheets with this turbo, or ar you letting your customers do 100% of the testing for you?
#78
Originally Posted by GUITARJUNKIE28
452 @21? i'm glad you made the numbers...
If you knew the deal ron gaveme on my kit INSTALLED you would think twice.
As far as the dyno sheets to prove it. I was interested in Gothams GR74 kit and when i talked to him about it....it wasn't tested yet or a unit sold.....but the maps and numbers add up was the answer i was given. Ron is a damn genious with this car. Every conversation i have with him i learn some new things.
#79
Didn't Ron sell you the AF61R turbo kit, Fuel injectors, rail, resistors, pump and aeromotive fuel pressure regulator for 1800 installed?
Didn't he also built your intercooler piping and install your 3 bar map sensor for free too?
Yeah, seems like Rons really trying to take peoples money.
#80
But yes that was the deal i was given. ALL BRAND NEW PRODUCTS....1600's, SUpra pump, etc etc
#81
i never said that. i asked how he knew what the turbo could do if he didn't have a compressor map. i'm still waiting for an answer.
and max efficiency of 82%? that's great!!! but where? what flow rate for what boost level.
if you don't know that, there's no way in hell you can say it's 82% efficient on a 13b, ported, or unported at some specific boost level, because you simply don't know. THAT is why you need a compressor map. you can't just look at the compressor housing and say "oh yea, that's big...it's gotta put out power!!one!"
#82
There is no compressor map so quit asking. It's bad *** turbo. All you're going to get is dyno sheets.
Here is another 420whp @ 14-15 psi sheet. This was done on a TII/pump gas/AF61R combo with a stock cat.
Ignition break up too. Not that you care since you'll just come back on the offensive.
#83
Who cares........ it's obvious you're only wanting to cause trouble. There is no better turbo out there for the price.
you don't see a problem with this? supposedly 82% efficiency, but god knows where, god knows how much it flows, and god knows what it's capable of. YOU may be ignorant enough not to care about these things, but other people do want to know what they're buying.
so far, all i've seen perfomance-wise puts it on par with a 60-1 ($500 turbo).
let's see what it really does in the upper boost levels.
#84
I would really like to see you call me ignorant if we were face to face.
#87
It hasn't been maxed out yet.
#88
Originally Posted by III Gen X
How do you think it would compare with the 70mm race turbo you just posted in the FS section, which you say is limited beyond 650hp?
#89
Maybe we'll find out where the turbo max's out with my car....i'm rebuilding the engine now....I made 452.1 on STOCK PORTS.....the guy i bought my car from lied to me about the street port. So ron is doing a stage 3 street/race port. When i max out the AF61 i plan on switching to a AF70. Bad part about my having to rebuild cause of oil starvation somehow the E-shaft went caput YAY more money down the hole. I also need to add another nippndenso pump and hook it up with some 850's in the primaries and larger fuel line just to make sure i don't drop off on the fuel pressure again at higher boost. There may be something instore for this next tune this summer. But gotta see how my financial and employment situation turns out.
#90
I could care less what the compressor map says. I've driven/road in a AF61R car and it out performed every RX7 I've been in. That includes the APEXi R6, GT35/40, T78, T88, T51R KAI, T04R, T04E, T04S and T-61.
don't try to pick a fight with me just because you're too ignorant to read, or understand the importance of a compressor map.
#91
#92
well let's just tear this down a little bit, shall we? let's pretend everything goes your way and you knock the **** out of me good n' proper... let's even say you give me the beating of a lifetime, then you run me over with your car.
after that, you STILL don't know how to read a compressor map, and you're STILL ignorant!
#93
#95
yea, i'm sure you'll try to dazzle me with your wit.
just do yourself a favor and stop talking. every post you make makes you look more idiotic.
#97
the problem with people like you is you're not intelligent enough to even realise how stupid you sound.
#98
I'd like to point some power and torque figures out, assuming the boost levels given in the post are true. Using KaoticFDR1's dyno sheet as a reference posted on pg 5:
4000rpm 90hp 120ft/lbs torque
4500rpm 130hp 150ft/lbs torque
5000rpm 170hp 180ft/lbs torque
5500rpm 230hp 210ft/lbs torque
6000rpm 290hp 250ft/lbs torque
6500rpm 355hp 290ft/lbs torque
7000rpm 450hp 335ft/lbs torque
Compare this turbo to these GT35 turbos done on several different engines by several different people performed quite awhile ago:
http://dyno.zeroglabs.com/graph.php?...1&SUBMIT=GRAPH
It's very high-end peaky, atleast on that engine it was done on. About the only real good thing this turbo has is a beefy turbine setup with not enough compressor. No doubt it would more than likely atleast level off in power and torque, if not arguably continue building it up some to 8000rpm. Even then, it's not very condusive to street use as it's more limited to higher RPM usage, leaving the mid-range something to be desired. It's great on the turbine side; shy on compressor, having to run stratospheric boost levels to get power out of it. This turbo, with some more compressor, with its nice and fat turbine side, would do well I think on a high-overlap motor such as a bridgeport, but is nowhere near as good for stock/street port performance as some of the old mainstay, workhorse turbos that've been around for years and years such as your garden-variety TO4B's and E's, 60-1, etc.
"15psi by 4500rpm" (or whatever it was, which yields a mind-boggling 130hp and blistering 150ft/lbs of torque)? Is that what you guys are saying it does? Big power, early spool? Like I've said so staunchly so many times in the past, it's exactly what I've thought it was all along: this is nothing more than a John Deere (Schwitzer) S300 derivative turbo; no special wheel, no special this or that, no special nothing done to it. I've shown this over and over again not only with specifications but also with comparison pictures of the AF61R on Ryan Scott' engine and our John Deere S300S008. Heck, you guys eviscerated me both in public and in PM's, denying that it was a John Deere anything, then just a few days ago a forum member here gets one of these turbos that you guys shipped that didn't have the (gasp) John Deere logo scratched off of it! I've said it before, months ago, and I'll say it again; story unchanged -- This is not a custom-built turbocharger done by collaboration between this outfit and Garrett; not one bit. It has been and is being falsely advertised.
For those of you that are satisfied or are having success with this turbo, more power to you. I'm happy if the customer is happy with what they've spent money on. However, recognize the facts behind this unit -- you may not be getting what you're paying for.
As for an alternative turbo -- Master Power T-70, P-Trim-T4 type exducer, much better suited to a stock/street ported 13B, with a better balance of compressor and turbine, which actually is made using Garrett parts, $550-$600 on eBay brand-new.
To Lupe, Ron, and cohorts: go ahead, cuss me out, make fun of me, call me names, and all that middle-school jazz. It will prove yet again, as has been shown many times in not only this thread but in related others, that you have to resort to that line of trifling and adolescent behaviour because the truth is not in you.
Regards,
B
Regards,
B
#100
You could atleast use a dyno sheet from a car that wasn't broke.
