Old 12-09-17, 04:09 PM
  #6701
79 w 13B4port
rwatson5651's Avatar
excellent work. Can we see a rear view?
Old 12-09-17, 08:30 PM
  #6702
Old [Sch|F]ool
peejay's Avatar
My 84 is getting raunchy so i bought a new shell for its mechanicals.
Old 12-11-17, 02:27 PM
  #6703
seattle seven
lwrobins's Avatar
Blackout
I've been toying with this hood blackout idea...
Old 12-18-17, 12:42 AM
  #6704
RX HVN
7aull's Avatar
Clean look! not sure this would work as well on any other color?!
Stu Aull
80GS
AZ
Old 12-18-17, 01:59 PM
  #6705
Always Wanting to Learn
DreamInRotary's Avatar
KCREPU that is gorgeous! I'd like to do something similar for my center console, just not sure I have the patience to accomplish a job that well done. Will look amazing in the car to say the least!
Old 12-18-17, 10:34 PM
  #6706
Out In the Barn
Veteran: NavyTenured Member 15 Years
KansasCityREPU's Avatar
Received 1,061 Likes on 841 Posts
Thx - I've since cut the lower holes for the gauges and need to give it a respray. I hate that Rust-Oleum paint and primer in one. It looks good but the can sprayer fails most of the time.
Old 12-22-17, 01:50 AM
  #6707
RXChevin's Avatar
Any intrest in a build write up
Hey all I can't thank some of you enough. The forum has been great and the build threads that everyone posts are an amazing help. Ive been using the writeup's from wangracing and Viking War Hammer and just wanted to see if there was any interest in me doing one as well.
Old 12-22-17, 01:54 AM
  #6708
RX HVN
7aull's Avatar
Safe to say most EVERYone enjoys a vicarious follow of a good project. Undercarriage clean up you have done is EPIC. Good luck.
Stu Aull
80GS
AZ
Old 12-27-17, 08:48 AM
  #6709
JSmall's Avatar
That underbody looks incredible
Old 12-30-17, 09:11 PM
  #6710
Damn, it did start!
Richard Miller's Avatar
any picture before you sprayed? what kind of rust issues if any did you have to contend with? What did you use for a coating? Also that is a great purple.
Old 01-26-18, 08:46 PM
  #6711
klptk's Avatar
I spent the last few days pulling my rear axles and got new bearings put on today. Years of curbing had the passenger side grinding but slipping off a rhino ramp really gave it the clunks.
Maybe a dumb question, but I read a post saying to put bearing grease on the axle seals for assembly. Will coating with a bit of diff oil work fine?
Old 01-27-18, 10:29 AM
  #6712
meifert's Avatar
Cracked a housing and rotor.
Old 02-09-18, 08:39 PM
  #6713
Member of one
ricsrx's Avatar
Old 02-09-18, 08:40 PM
  #6714
Member of one
ricsrx's Avatar
Old 02-10-18, 12:51 PM
  #6715
meifert's Avatar
Helped unoack the SR20DET for the swap. It came with quite a few extra oarts that will be sold to offemset the cost of everything involved. Also, stripped the Ford 7.5 down for the brackets to be welded on
Old 02-20-18, 09:02 PM
  #6716
Old [Sch|F]ool
peejay's Avatar
Old and busted vs. new hotness.
Old 02-23-18, 07:48 PM
  #6717
Member of one
ricsrx's Avatar
fuel access
Old 02-27-18, 05:40 PM
  #6718
Old [Sch|F]ool
peejay's Avatar
Old 02-28-18, 11:59 AM
  #6719
Lapping = Fapping
Jeff20B's Avatar
Think this one will be less breakable, peejay?
I see you have a dual bolt pattern on the flange; good thinking.
Old 02-28-18, 09:31 PM
  #6720
Old [Sch|F]ool
peejay's Avatar
It's a single bolt pattern. I had Da Boss chuck up the Ford flange and machine the inner OD a little larger to accept the Mazda spigot diameter. I gave him a Kia Sportage front driveshaft chunk for reference The Mazda bolt holes are merely drilled in where there wasn't a Ford pattern in the way.
Having major difficulties getting the Watts to work with it.
Old 03-07-18, 11:44 AM
  #6721
Freeskier7791's Avatar
Ric, your car looks pretty epic, what all are you doing with it?
Old 03-07-18, 12:04 PM
  #6722
DWNUNDR's Avatar
what seat mounts are these???
Old 03-08-18, 02:38 PM
  #6723
Member of one
ricsrx's Avatar
I am not sure...i have owned a few 7s in my life and always wanted to go crazy on one. I just want mostly to terrorize the neighborhood
Old 03-11-18, 06:30 PM
  #6724
1st-Class Engine Janitor
DivinDriver's Avatar
Passed smog... again )
Old 03-15-18, 01:17 PM
  #6725
Sounds fun!
Quick Reply: What did you do to your FB today?
