26B PP Eunos Cosmo
#101
Thanks, making these few lines has been the most frustrating part of the entire car so far.
I wish, everyone is saying the same thing
Haha thanks for your praise. I'm an aircraft engineer so some of this stuff sort of just follows on from what I do at work. Looking through this forum has been a huge help also. Might have to start a "how to" YouTube series next.
#102
Completed the airbox assembly today. All powdercoated. Just need to work out how to seal the ram tubes to the lower base plate.
Rotor housing for size comparison.
#104
Got a few more bits in the mail. A set of 8 used bosch 1000cc fuel injectors. The fuel and oil pressure sensors and 3 temperature sensors. Found a used 3 gallon dry sump tank on ebay so that will turn up soon.
temperature sensors on both inlet and outlet.
Close fit.
Close fit.
Redrumls (08-22-17)
#107
A rubber o-ring won't work because the bolts are really close to the edge of the holes on the baseplate. I have access to a laser cutting machine at work, So will probably cut out some dense EVA foam which will be stuck onto the baseplate.
#108
The car has a radiator now. Its a universal fit radiator but its a millimeter perfect fit in the car. It has been modified by the local radiator shop. They added the mount lugs, -20AN fittings and converted it to triple pass configuration. It uses the original lower mounts. Im making a duct/mount for the top.
Originally the car has 2 oil coolers mounted beside the radiator, same as an FD rx7. Im going to be mounting the oil cooler in front of the radiator. A few reasons for this. 1. The holes in the bumper are too small for any decent airflow for side mount coolers. 2. The ducting is a lot simpler. 3. The complexity and cost is a lot lower with 1 cooler. 4. The radiator fan will also work for the oil cooler.
lower mounts, the rubber parts are 1973 Holden Torana suspension bushes.
Davies Craig 150L/ min water pump.
Upper duct, still needs some work.
using the orignal mounts means the factory undertray can still be used. This saves a lot of time making something.
#112
Awesome work James. Have not checked your thread in sometime! Good idea modifying the radiator to be be a three pass. I have my oil cooler set up the same. Works a treat!!
-Dave
-Dave
#113
Thanks mate
Thanks Dave, do you know if there is much of a pressure drop across your oil cooler?
The oil tank turned up last week. Its a 3 gallon Patterson tank. A used Ebay deal from North Carolina. Cut a big hole in the inner guard, close fit approx 10mm to the tyre on full lock. Just need to sort out the mounts for it.
The intake manifold is starting to take shape
#114
The intake manifold is looking very nice. I've started on mine. Sent you a PM.
#116
finished the upper radiator mount. The intake manifold is all tacked up, needs final welding then paint. Pushed it out the shed for a few photos.
rotatrix (09-20-17)
MK3Brent (10-31-17)
#122
Haha, yeah its a big air filter but looks really cool i reckon.
The rx7 had a front cover o-ring blow out on the dyno this week. I used the wrong gasket. Easy fix, back up and running again.
Did a run of powdercoating, did the oil tank and radiator support. (The blue fittings will not be staying)
Purchased 8x AEM smart coils secondhand, have started making a bracket for them.
#124
Nah, doesn't impair vision at all. I'm 6 foot 3 , So I'm looking out the top half of the windscreen anyway.
#125
The radiator is finished now, looks great with the fan mounted to it. The fan is a Flex-a-lite 180. The water pump connects directly to the radiator.
The oil cooler finally arrived yesterday. ( 5 week wait ) . Its a Fluidyne cooler, seems like a quality unit. Its 3 inchs thick and its half the price of an equivalent Setrab.
The ignition coil bracket is just about finished.
Something a bit different is the oil filter pedestal made by Peterson Fluid Systems. It has a primer pump built into it, you just wizz it up with an electric drill if the engine has been sitting awhile.
