Running a FD N/A?
''I Like The Tuna Here''
Running a FD N/A?
Hey im looking to remove the twins and want togo single but its alot of cash anyway i can run the fd without the turbos? And if so what will i need to do to get it running for the tine being.
half ass 2 or whole ass 1
In agrreance with what everyone else is saying. I find it interesting that we went from this
https://www.rx7club.com/3rd-generation-rx-7-1993-2002-vehicles-107/full-re-gt300-widebody-fd-1105687/
To this thread... I have a feeling the attempt to go n/a will be made anyway followed by a part out.
You just need an NA 13B header ($250) and will have to have a mid-pipe custom made to connect the header to the cat back section ($???) and a Power FC or other aftermarket ECU (stock base tune will be fine) ($500-1,500) and put an air filter ($25) on the throttle body elbow.
Probably want a cat (stock is fine) or all stainless pre-silencer in the mid-pipe since NA rotaries are LOUD.
Then you can remove as much emissions and twin turbo items as you want. If you just remove the twin turbo controls and leave the stock ECU you will get codes and probably a limp mode.
If you want to run stock ECU you can do that too, just leave all the twin turbo solenoids (rat's nest) in place.
Should make 150-180rwhp depending on whether you tune it or not.
I ran my FD na for close to a year back in 09'
bought it non running turbos toast, wiring harness taken off to rewrap.
I bought a power fc and a used set of twins.
put them on and they just poured oil out. Total junk.
wasn't sure if it was oil control rings or turbos for sure
bolted a used fc header on, blocked off the oil feed,drains and coolant.
cut off the tb flange and welded one on the right size and angle to bolt to FD stock cat.
drove it na and no smoke screen. Tried a couple other junk sets and ended up waiting and saving up to have them rebuilt out of 5 sets of bad twins.
I am interested in what a REW would make NA as SCCA has a race class where engine swaps are allowed. Including engines that came factory turbocharged, but with turbos removed.
With no porting allowed in engine, intake, or exhaust, but seals, coatings, balancing, ecu, exhaust are free what could an NA REW make? would it make similar or more power than a S5 NA?
Same question with the S4/5 TII 13b minus turbo.
Gilgamesh
Looks like one that made the most power was 182.4PS or 180rwhp.
Injection NA
<Basic Plan 1>
+ E-manageUltimate injection NA sample vehicle
Base vehicle: RX - 7 (FD 3 S)
H7 year
Mileage: Approximately 65.000 km
Compression test F: 7.7 / 7.8 / 8.0 / 250 rpm
R: 8.5 / 8.2 / 8.5 / 250 rpm
External (HKS) muffler wearing
#31 on this page list
p[`FbNLO
Pretty good.
You can see entry #21 was 13B-REW with streetport and 9.7:1 rotors and did 208.4ps.
If the Original Poster can use any stock internal with stock intake manifold 13B the 13B-MSP seems to be the best.
Also cheapest on Ebay with $1,500 complete engine/trans available.
Entry #17 is their project RX-8. It did 180.7ps as RX-8s do and then they were able to tune it up to 220.5ps (217.4rwhp).
Here is the link to their blog on it-
RX-8@SE3P@ƒfƒ‚ƒJ[
https://blogs.yahoo.co.jp/anniversar...E3P+%A5%C7&p=6
RX-8@SE3P@ƒfƒ‚ƒJ[
No, I'm sorry.
Looking at the Yahoo blog for the RX-8 it looks like they may have used the Racing Beat intake manifold/adapter to get up to the 217rwhp.
Makes sense since the most I have heard of from professional racing RX-8 with stock engine, stock intake manifold is just over 200rwhp.
The a car with the renesis will have to weigh 3,000 lbs and have a 55mm restrictor.
The Cosmo 13b minus the turbos could be an option as well.
The 13B NA weight is at 2650 right now.
on
