Headlights won't turn on, high beams work?
also ended up finding the culprit for my headlight issues it was the relay by the fuse box which I replaced last year.
opening it up it looks brand new on the inside, no corrosion anywhere, looks like it welded itself shut
I had it hanging upside down, funny how electromagnets don'st work underwater
Twin Turbo LSX
Back from the dead. I never replaced the relay, just hitting it with a screw driver resolved the issue.
Well, I had the relay act up again a couple weeks ago. I found the replacement part in stock and cheap at Advance and figured I'd share the part# for the next guy who has this problem.
Part No. R4136Z $17
http://shop.advanceautoparts.com/web...RPRELAAMS____#
Part No. R4136Z $17
https://www.oreillyauto.com/detail/b...q=250278&pos=0
RX-7 Bad Ass
If you flash high beams I don't believe they are designed to pop up. You have to press the pop up button or turn on headlights then flash.
Dale
Dale
HOBODRIFT!
13
04-03-11 05:16 PM
nunchuckgun
8
12-18-08 10:59 PM
gizmo_kla
05-28-06 09:11 AM
UnderConstruction7
02-08-05 08:17 AM
