Another Jason Another Basic FD Build
Old 02-14-17, 11:43 AM
  #76
#FakeCarEnthusaist
Brody8877's Avatar
Originally Posted by kensin
that might just me my issue
my twins are boosting 10~5~6psi
my initial thought was because my pills were not in the lines so i replaced them
bus still havent test it yet. if that dont fix it ill try swapping those .. thanks
Troubleshooting
RX7 Solenoid PRE/WG Duty
The solenoid is right behind the vacuum chamber tank. Make sure the connector with the white dot is connected to the solenoid with the white dot, if the dot is missing, connect the connector with the white dot to the solenoid that is on the driverside (LHD). I hope this help, let me know how it goes.
-Jason
Old 02-18-17, 01:38 AM
  #77
Put it in the microwave!
kensin's Avatar
did i connect it correctly ? my harness is pretty new
Old 02-18-17, 01:41 PM
  #78
#FakeCarEnthusaist
Brody8877's Avatar
Yup, white dot goes with white dot.
Old 03-04-17, 10:52 PM
  #79
#FakeCarEnthusaist
Brody8877's Avatar
Minor Updates - 3/4/17
- Dale Clark Viton Check Valve replacement
- 99 Spec Tail lights
Old 03-07-17, 02:05 PM
  #80
Dhanson31's Avatar
Hey Jason killer build! I actually just bought a bw s362, and was doing a very similar build (how I stumbled upon this thread). Was wondering if it was possible for you to email me or PM me. Going to follow this thread and sort of follow in your footsteps if that's alright. I'd like to get your contact info in case this thread ever gets lost lol! Let me know. Greatly appreciated. Keep up the good work!
Old 03-12-17, 05:40 AM
  #81
#FakeCarEnthusaist
Brody8877's Avatar
3/11 another minor update
*362sxe project put on hold until end of this year
-heat shielding and barrier for the ic piping and the smic
-weather stripping to seal off the smic duct
-denso race plugs (yay for no more ignition break up under boost, hope they last longer than the NGk platinum plugs
-replace the hks mushroom foam filter with k&n filters
-replace the torn exhaust ground
-replace some of the ic coupler with expandable hump
-replace some of the worm clamps to all t-bolt for the ic piping
-did an oil change with idemitsu 10w30 oil
-finally bought a premix kit, so i can stop being lazy on pre-mixing.
No more excuse! Lol .__.
Old 03-12-17, 09:55 AM
  #82
kensin's Avatar
awesome stuff. where did you get the hump coupler ?
Old 03-12-17, 01:31 PM
  #83
#FakeCarEnthusaist
Brody8877's Avatar
I go to most of my couplers and t-bolt from atp turbo.
-jason
Old 03-12-17, 07:28 PM
  #84
#FakeCarEnthusaist
Brody8877's Avatar
Everything put back together
Daytime pics with everything put back together.
Old 03-21-17, 11:56 PM
  #85
#FakeCarEnthusaist
Brody8877's Avatar
Some updates:
retuned by Daniel of garage life
video below
View this post on Instagram
Results: 280rwhp 260rwtq sae corrected.
Old 03-23-17, 01:56 AM
  #86
#FakeCarEnthusaist
Brody8877's Avatar
Some goodies
supernow rear tow hook and rear end links
Old 03-23-17, 09:55 PM
  #87
kensin's Avatar
Originally Posted by Brody8877
Some updates:
video below
https://www.instagram.com/p/BR4YW-0hyvQ/
numbers look healthy. stock twins 12psi ?
Old 03-24-17, 11:58 AM
  #88
#FakeCarEnthusaist
Brody8877's Avatar
Stock Twin around 11psi.
Old 03-25-17, 03:22 AM
  #89
#FakeCarEnthusaist
Brody8877's Avatar
Spending my Friday night assembling the ohlins.
Old 03-25-17, 03:39 AM
  #90
Rx7 Wagon
Narfle's Avatar
Nice! Does the supernow rear hook require the stock rear tow mount to work? There's an extra stock bracket that's not on all of them for some reason.
Old 03-26-17, 10:24 AM
  #91
It Just Feels Right
TomU's Avatar
That's quite the liberal application of gold wrap there. I'm not sure if the IC hot side should be wrapped, if the air charge is hotter than ambient temps. The intake on the other hand, probably should be wrapped.
Old 03-26-17, 06:59 PM
  #92
Johnny Kommavongsa's Avatar
I just assembled ans installed new ohlins and man arent they awesome?
Old 03-27-17, 02:02 AM
  #93
#FakeCarEnthusaist
Brody8877's Avatar
does not require stock tow hook
I still have a lot of heat reflective tape left. I just half *** with the wrapping :/
Duuuudeee they feel great.
Old 04-02-17, 04:10 PM
  #94
#FakeCarEnthusaist
Brody8877's Avatar
Update: A bit of bad news, I accidentally beached my FD on my driveway again and ever since then I had very noticeable exhaust leak and smoke coming from the engine bay area. I was hoping I have damaged my downpipe, but after replacing my downpipe, I still have same noticeable exhaust leak and smoke. I was able to isolate the location of the smoke and it was coming from turbine housing on the primary side. It seems like the twins are officially done. Hindsight is always 20/20, I should have focus on the single turbo conversion instead of rushing to get my car somewhat track ready with the twins.
Back on track with the S362sxe project.
Old 04-02-17, 08:26 PM
  #95
kensin's Avatar
damn dude ;( and you just got it tuned too.
what did you mean by you beached the fd lol
oh if you move onto the single built. I'll gladly take the blitz smic and duct off you ....
Old 04-02-17, 08:39 PM
  #96
Rx7 Wagon
Narfle's Avatar
I've heard it called high-siding before, too. When there's a ledge or change in grade, long and/or low vehicles can become stuck or scrape underneath when the ground "rises up" under the car.
Happens to big rigs on train tracks.
Old 04-03-17, 12:22 PM
  #97
#FakeCarEnthusaist
Brody8877's Avatar
Narfle nailed it lol. It's an RE-Amemiya SMIC with a pettit racing duct. I will be parting out the twin turbo stuff soon.
Exactly what happened
Old 04-03-17, 01:00 PM
  #98
#slevin's Avatar
If your ditching the twins real soon I'm interested in your intake. HKS right?
Old 04-03-17, 05:18 PM
  #99
#FakeCarEnthusaist
Brody8877's Avatar
Correct, HKS RS Intake. Once everything is off the car, a FS will be posted. It will be first come first serve.
Old 04-16-17, 09:31 PM
  #100
#FakeCarEnthusaist
Brody8877's Avatar
It's official, twin turbo part out, time for single.
Quick Reply: Another Jason Another Basic FD Build
