The Hillclimb RX7 - a saga
Old 03-09-16, 09:21 PM
  #351
RGHTBrainDesign's Avatar
It sure is incredible though. Easy is for the weak.
Old 03-11-16, 09:28 AM
  #352
DaveEstey's Avatar
Was rebuilding the Ford diff last night and forgot a shim on the pinion, which meant I had to pull the bearing off - wrecking the bearing. New bearing incoming.
Old 03-11-16, 10:54 AM
  #353
1308ccs of awesome
eage8's Avatar
that shim sets the pinion depth... so you'll need to take it on and off until you get it right.
most people use a crappy/used bearing and grind down the ID of the bearing so it just slips on so they can test with it.
or you can get a setup like this which relocates the shim to the other side.
Severe Duty Pinion Shims
Old 03-11-16, 11:06 AM
  #354
Fistful of steel
LargeOrangeFont's Avatar
You can also get a solid pinion spacer from Ratech. It makes changing a pinion seal a snap if you ever have to. You never have to deal with the crush sleeve.
Old 03-15-16, 06:25 PM
  #355
DaveEstey's Avatar
Well the Surtrack (SURTRACK FD8170) Ford axles I ordered don't work for this. The bear is a red one too small to fit the Ronin axles. Very annoying since I had to take these new axles apart to figure that out.
Old 03-15-16, 08:31 PM
  #356
Fistful of steel
I would order used OE axles on eBay.
Old 03-18-16, 01:03 PM
  #357
DaveEstey's Avatar
Yeah looking for used OEM now.
Meanwhile, the Miata, with 40k miles, needs a rear wheel bearing. This job sucked.
My version of fuller house
Old 03-26-16, 10:51 AM
  #358
DaveEstey's Avatar
I did a thing
17x10 +25 offset. Needs a spacer to clear the springs in the front.
Old 03-26-16, 03:01 PM
  #359
Fistful of steel
That'll work! What do you need about 15mm or so?
Old 03-26-16, 04:22 PM
  #360
DaveEstey's Avatar
Yeah, going to order up 4 spacers and longer wheel studs too
Old 03-26-16, 06:44 PM
  #361
Fistful of steel
I hate doing that.. The ARP 3.25 studs are $32 a side.
Old 03-26-16, 08:15 PM
  #362
1308ccs of awesome
eage8's Avatar
that's what I have for my street wheels
but their +35s... with 315s on them lol.
I'm running 30mm spacers on front and 20mm on the back and it's pretty close... (because of the tires)
why did you swap? I thought your old wheels were decently big 15s? 15s and 16s are a good slick size... 17 I didn't think was. (I could be wrong). do they make a 23-24" slick for a 17?
Old 03-27-16, 08:11 AM
  #363
DaveEstey's Avatar
I have 15x10 steelies.
These are a little lighter and with the 5.14 gears I don't need a 22.6" diameter tire. I can get 275/35-17 A7s, which are 24.6"
These also clear the brake calipers much better around the basket area and I got the full set with tires - that will be given away - for $400
Old 03-27-16, 09:37 AM
  #364
Fistful of steel
Good deal..
Old 04-07-16, 06:56 AM
  #365
DaveEstey's Avatar
Freezer is full of wheel bearings as a contingency plan for a "While I'm in there" situation while installing my new ARP extended wheel studs. (Thanks J-Auto)
Spacers got dropped off at the machine shop to get a little tuneup to fit more nicely.
Meanwhile, I need to get off my *** and get the shop to finish up my rear diff, because my driveshaft FINALLY shipped yesterday. Apparently it takes more than a month to manufacture a carbon fiber driveshaft.
Old 04-08-16, 05:58 AM
  #366
DaveEstey's Avatar
Fronts = easy. Rears = UGH
Old 04-09-16, 07:36 PM
  #367
DaveEstey's Avatar
Rule #1: If it's apart, it gets cleaned and painted before going back on the car.
Old 04-10-16, 04:41 PM
  #368
Raced Regularly
driven-daily's Avatar
Do you have a blasting cabinet, or are you using some other method of cleaning?
Old 04-11-16, 09:17 AM
  #369
DaveEstey's Avatar
elbow grease. Blast cabinet is on the "to-get" list.
Old 04-11-16, 09:19 AM
  #370
DaveEstey's Avatar
Rear subframe and diff is all out to get cleaned up and prepped for the Ford unit.
Old 04-11-16, 03:55 PM
  #371
DaveEstey's Avatar
Fresh and clean once more.
Old 04-13-16, 03:13 PM
  #372
Fistful of steel
I only clean stuff when it comes off, I don't repaint. but my car is a California car, so there is really only dirt, no rust.
Old 04-14-16, 10:23 AM
  #373
DaveEstey's Avatar
She's not rusty - never seen winter - but 30 years of aluminum oxidation would take forever to polish out. Much easier to give it a good clean and a shot of paint to protect.
Meanwhile -
I know when that driveshaft bling. That can only mean one thing.
Re-doing the fuel system while the rear suspension is all out. Much easier to access. Switching from braided -6 to lightweight aeroquip 8
Old 04-14-16, 10:44 AM
  #374
Fistful of steel
Meanwhile -
I enjoy knowing there is a protective coat of oxidation on all my raw aluminium parts. Looking good.
Old 04-15-16, 07:40 PM
  #375
DaveEstey's Avatar
Finished refreshing the diff and installing my gears and LSD last night. Might actually have this in the car this weekend!
Quick Reply: The Hillclimb RX7 - a saga
