T56 tranny to FD
Old 02-28-07 | 08:11 AM
  #201
paul_3rdgen's Avatar
Too cold in the garage
Howard, don't tell people you are copying mine! just kidding......LOL
Old 02-28-07 | 08:59 AM
  #202
Howard Coleman's Avatar
Racing Rotary Since 1983
hey Paul, what can i say.... i like to weld. i happen to have some 1/2 inch stainless plate lying around along w some chrome moly tubing. and i know a great idea when i see it. i do plan to use a foundation plates between the tubing and the subframe to spread the load a bit.
o k, i owe you an idea. feel free to pm me on anything and i will do my best.
regards,
h c
Old 03-03-07 | 01:02 PM
  #203
CMonakar's Avatar
rebreaking things
Originally Posted by wanklin
That's the TR-6060 I believe. Costs about 10k from the factory....
http://wheeltalk.fancal.net/?cat=33
[/indent]
Thanks for the link. Wanklin, who told you the TR-6060 costs $10,000? According to Wikipedia it is being used on the Pontiac G8 and Dodge Challenger. I doubt it would be used on those cars if it is that expensive.
I spent some time searching the web for more info and it looks very promising. Ideally, I would like to find a gearbox that measures 26.4" from where the bell housing mates up to the motor to the center of the shifter mount. I think I could get pretty close to that with the design of the 6060 tail section in the photo posted above. I recall seeing a T56 with a similar tail section a few years ago, so I'm not sure that is one of the things that differentiates the TR-6060 from the T-56
The gear ratios seem good too. In comparison to stock:
1st: 117%
2nd:113%
3rd: 107%
4th: 100%
5th: 90%
6th: 75mph @ 2,625 rpms with a 4.1 axle ratio and 16x225 50 tires
For those of you that are still thinking about using a transaxle I found a few photos in my archive:
Not exactly petite
I had a transmission shop take the measurements listed below, so I can’t vouch for the accuracy, but a second shop did confirm them.
Measuring from the back of the car 25" puts the front of gearbox where the rear aluminum chassis brace is located.
This is approximately where that point is inside the car with the seats moved all the way back.
Obviously the tunnel flares out near the floor of the chassis, but not enough! Also notice how far forward the gearbox extends. Based on this I concluded it was not worth doing the swap (if it is even possible) since the weight shift from front to back wouldn't be too significant.
Old 03-03-07 | 01:48 PM
  #204
wanklin's Avatar
Rob
Good info Chris. I should have saved a link for the price info, but I saw that 10k figure estimated in two different forum discussions related to the GT500 before its release, which ofcourse means nothing. I think scarcity may be at play temporarily and ofcourse it would cost you twice as much to buy parts to build a car than to buy one preassemled. 10k seems a tad high bt i wouldn´t be too surpised with something so new. we´ll just have to call the SVT stealership and see what they say.
From what I gather, Tremec has completely revamped the t56 and added the 6060 to the line-up. both will be used for various high output OEM applications.
Old 07-06-07 | 02:24 PM
  #205
CMonakar's Avatar
rebreaking things
Originally Posted by IronMdnX
Does anybody have access to a FD auto bellhousing. It would be interesting to see if it is the same debth as the 20b's.
Old 07-06-07 | 09:12 PM
  #206
PureDynamics's Avatar
Originally Posted by CMonakar
Damm Wish I saw this two weeks ago.. I just have my trans out getting repaired.. I'll swing back by the shop and see if he's got one around..
Old 07-07-07 | 05:58 PM
  #207
IronMdnX's Avatar
Glutton for Punishment
Just an update. I have finished installing a 05 gto tranny and it works great.
here is a link to the thread in the 20b section
https://www.rx7club.com/20b-forum-95/tranny-update-655772/
Jetlag
09-29-15 07:52 AM
