Spring 2011. Updated pictures.& Specifications. 1989 Turbo II LT1 T56 .
1989 Turbo II
on
This is the 2nd winter I work on my 1989 Turbo II and here's how it sits as of March 12 2011.
1989 Turbo II
on
Specifications :
Lloyd Elliot LE2 package. www.Elliottsportworks.com
-Fully Ported heads milled 0.030" with 0.56cc chamber, casting 10128374.
Manley 2.00/1.56 6000 series valves.
PAC 1218 bee hive springs (145 lbs seat and 340 lbs open)
Steel retainers and locks.
205 cc intake port flow about 275/190 CFM.
-12.05:1 Comp. Ratio , 230PSI Compression.
-CompCams Pro-Magnum Roller rocker 1.6:1 7/16" studs "NSF" (None Self Aligned).
-850-16 CompCams Hi-energy hydrolic roller lifter.
-7937-16 CompCams Hi-Tech Pushrods 5/16"X7.050".
-MR-1896 Sealed Power 5/16" Guide Plate.
-Fully ported Intake manifold casting 12552138.
-AS&M 58mm Throttle body.
-Ford Racing SVO 30 Lbs. Injectors.
-Custom camshaft 223/230 .565/.565 112 LSA .
-Fel Pro 1074 head gaskets .039".
-Fel Pro 1284 intake gaskets.
-Autolite #104 0.030".
-Hypertech 160 degree thermostat.
-MSD 83811 Pro-Billet Distributor.
-MSD 8226 Blaster coil.
-MSD 32149 8.5mm Spark plug wires.
-TPIS High flow mass air sensor housing.
-Meziere WP118HD Electric Water Pump.
-Holley 255lph fuel pump.
-Hedman 69640 modified for Fastburn "d" style GM exhaust port to 2.5" into 3" N1 Pipe to Magnaflow Muffler.
-Ford Taurus V6 3.8L electric fan conversion.
-Shortblock :
-385CI ( 6.3L ) LT1 4 Bolt main Corvette shortblock.
-Scat 9000 stroked lightweight forged crank.
-Scat forged rods.
-Mallory Forged Pistons -5cc.
-4045MS-15 .040" + .005" Mahle rings file to fit.
-Rings gap : 1st .018" , 2nd .020".
-ARP main studs.
-Melling 10555 High Volume Oil pump.
-Clevite 77 MS-909H STD bearings crank Bearings.
-Clevite 77 CB-663H STD Connecting rods bearings.
-12370835 GM single roller extreme duty timing chain set.
-Fluidampr Harmonic balancer # 740101.
-Balanced and Blueprinted.
-Cleaned, decked, bored .040 over and honed with deck plates, new frost plugs, etc.
-Transmision T56 6 Speed.
-Fidanza #198581 12.5LBS flywheel.
-SPEC 3 clutch 11" 26 splines.
-Centerforce 381039 clutch disc.
-Ram BA381 HD clutch pilot Brg.
-GM OEM release Brg. 10085246 (CT1080).
-Pro 5.0 Short throw shifter.
-Dorman #31052 Pinion snubber
-Abbott Electronic speedo converter.
Differentiel limited slip 4.10.
Suspension/Wheels
Stance GR + Coilovers adjustable with front/rear pillowballs.
Racing Beat DTSS Elims.
K2RD Rear Camber Adjuster.
Front STB.
5Zigen FN01R-C 17x8 +25 225/45/17 Nitto NeoGen.
5Zigen FN01R-C 17x10 +35 275/40/17 Nitto 555R Drag R.
Car weight with full interior ( March. 2010 ).
2888 Lbs.
Trending Topics
1989 Turbo II
on
April 25 2011.
1st run at the drag strip .
Nothing exceptional but it is my new personal best.
I know I can do better......
Video here.
..12.06 ET @ 117.60 MPH..
Video here.
1989 Turbo II
on
Update Juin 5th 2011.
I have driven 3820Km ( 2373 miles ) since the new motor is in with "0" issue what so ever.
The car is a blast to drive.
Today I did a round trip to Quebec city ( around 600Km ) and I've decided to check the fuel consumption ( Hwy and City ) and the result are pretty amazing.
I averaged 30.77 Miles per gallon ( 8.75 liter for 100Km ) @ 70 - 75 MPH ( 110-120 KMH ) and city I averaged 16 miles per gallon ( 16.8 liter for 100 Km ).
To get those results my driving was very civilised but still.
I'm very happy.
I'm very happy.
Your car is absolutely brilliant!!
I flip flopped many nights before I decided not to do a V8. I love the combination of the chassis and engine. I think it is a very intelligent choice..
Your car is inspirational. I wish I had gone the extra mile like you on some of the undercarriage detail. No matter, I can always do it later. I just want to get some seat time in my car.
Props my man, that is amazing work.
1989 Turbo II
on
Hello Rob.
1st I have to say ( as of Oct 26th 2011 ) that I have driven , so far , over 12,000KM with the new motor this summer ( 2011 ) .
Car is awesome and I had "0" issue what so ever with anything on the car except regular maintenance here and there that I will consider normal for a 23 years old car .
Car should go in storage around mid November depending of Quebec weather.
Here's my plan for 2011-2012 winter:
1st: Put back the original Power Steering rack you sent me last summer and I'll try to make it work with a Toyota MR2 electric power steering pump that I already bought earlier this year.
2nd: Will be adding A/C , I have bought everything new also earlier this summer so all I'm missing is custom hoses.
3rd: I would like to have the seat redone , nothing fancy , just refresh them.
4th....... I don't know to be honest.
I "may" remove my new motor , refresh the one I had in it ( 2010 ) , lower the compression and go Twin Turbo or supercharge it or just put some long tube headers, redo the exhaust line and add catalitic converter to my actual setup.
I'll decide later this winter.
I have 3 LT1 in my garage.
1 - 385 C.I ( 6.3L ) in the car right now.
2 - 355 C.I ( 5.7L ) "Original motor" from oil pan to throttle body with all electrical stuff ready to go in my car in case of a problem with my actual setup.
3 - A bone stock "untouched" LT1 for I don't know what. I have a spare motor in case if my spare motor breaks......
From what I can see is : what ever you do on a LT1 ( stroke it , beat it , etc. ) they don't seem to go bad and they are very reliable.
6.3L in the car :
Original motor :
GM LT1 5.7 Litre. 355CI Bore 0.030".
JE SRP Forged Pistons (10.3:1 compression).
Manley Sportsman Forged Rods.
GM hotcam Kit (hotcam, LT4 springs, 1.6 Roller Rocker).
Stock Aluminum heads.
Hedman 69640 Headers .
MSD Ignition.
CSR Electric Water pump.
Far left the bone stock LT1 :
I also want a paint job ( a real one ) but I'll strip the car in pieces to do that so I'm not ready yet.
I have the car since Oct 2009 and love it as much as the first day I bought it.
The car is so much fun and I get compliments everywhere I go from all groups of ages .
I have over 1200+ hours of work "fun" in the car.
I love working on it as much as driving it.
I just renew the plates "tag"on the car so I'm not ready to park it yet and I'll try to do a "End of season" video like I do every years if possible.
6.3L in the car :
Original motor :
MSD Ignition.
