View Poll Results: 4 rotor or 6 rotor
Voters: 38. You may not vote on this poll
1965 Dodge Polara 6 rotor project
Steam_Punk_Gen
on
![WA](https://www.rx7club.com/images/icons/wa.jpg)
need input should i do a dual 13b setup 4 rotor or a 3 rotor ultimately would like 6 rotor monster need help with all areas especially with transmissions, car that will be receiving this setup is close to 5000 lbs maybe even heavier
![](https://sphotos.ak.fbcdn.net/hphotos-ak-ash2/hs145.ash2/40607_149633668380582_100000018492574_475638_2916385_n.jpg)
Steam_Punk_Gen
on
nope its not april first my buddy needs the 383 big block thats in it and i want to do something never done as simple as that i like rotary engines so why not just through a big turbo on it change the apex seals and good to go
Steam_Punk_Gen
on
one complication i see with the six rotor is the length of the bolts needed to keep them together other than that firing order works on 360 degrees divided by six running in alternating pattern just like the four rotor 1,3,2,4 firing every 90 degrees so some simple math and we would be good, the other problem i am having right now is finding a sufficient amount of these engines to slam together and be carb, not fuel injection.
Trending Topics
the issue is eshaft flex.
Steam_Punk_Gen
on
OK. don't they use six rotor in aircraft though? can the 20b 3 rotor be compounded together if so wouldn't that solve the stress issue if the shaft is already able to take a three rotor attaching one more set shouldn't cause that much of a difference?
ok on top of that what turbo would you use one large or two medium size turbos.
I need a new user title
![](https://www.rx7club.com/images/misc/10_year_icon.png)
on
That was just a mockup done by Hurley Rotary; it never ran. The timing of this thread is funny because I was thinking about the engineering issues of a five- or six-rotor just this morning. The problem is just as Brodie121 says: e-shaft flex. The longer the engine, the bigger problem it becomes. That's why everyone stops at four (that, and turbo four-rotors are capable of such obscene power that it's unnecessary to go any larger in practice).
I don't mean any offense, but from the sound of your posts, you are not a professional mechanical engineer, so I recommend giving up on the idea of a six-rotor. Pay Jeff Bruce to build you a four-rotor kit, slap a turbo on it, and have fun.
Steam_Punk_Gen
on
how do you get around the ECU issue with a 4 rotor without having to spend 3000 on a Stand alone engine management unit because i want to turbo but don't know if there is a solution for carburetors, which would mean i have to do fuel injection but what do i do run both separate ecu
Likes to swear....alot
![](https://www.rx7club.com/images/misc/15_year_icon.png)
on
Carbs suck. They are just a slightly controlled leak.
As I said, I hope you have alot of $$ a real standalone is going to cost you $3000+
There is no way you will be able to complete such a project for cheap. Just being realistic.
Steam_Punk_Gen
on
there was a pretty good forum "ghetto 4 rotor" going for a while and it was insight full, i am thinking of 4 rotor 13b dual with a huge turbo out of my buddy's 1996 dodge ram he is giving me i am thing about more than 500 horse after i am done thats what i am aiming for.
Steam_Punk_Gen
on
plus i dont have 70000 New Zealand dollars = 51989.0000 US dollars to blow on a 65 polara never mind the 3000 grand i have going on the interior
