Final Photoshoot of Veilside Fortune Widebody with New Stereo Installed NO 56K
Final Pictures of my Veilside Fortune RX7. Car is going up for sale in the next few days.
Exterior Shot
Exterior Shot
Car also featured as the main car for Hot Import Nights Tour 2007-2008.
Picture of car on the HIN flyer
Picture of the car on the HIN tickets.
First the car can't go any lower. The front already hits the wire harness of the car even after being relocated it. We had it much lower the first time and it almost shredded the entire wire harness. We got very lucky.
Second the rear fender has too much build up on the top of the fender. We went with a more aggressive offset first and it almost cracked the rear quarter panel. These fenders are fiberglass not metal. The design of the actual body isnt quite there. The wheel housing is actually more narrow than stock so you are limited with what tires you can run. The car has room for a 20x13, but the 345/25/20 tire hits the fender because of the overall rolling diameter.
Trending Topics
I normaLLY don't like bold kits like that, most of the time I find them ridiculous... but that is the hawtness.
Of course it's about 1% away from not being able to be called an RX-7 anymore... it borders on something else.
That sounds wayyy too cheap to me. My guess would be double that...80k? The kit and bodywork alone cost around $20-25,000, plus cost of car, wheels, custom interior, etc. etc.
but whatever it is, im sure it will be high!
car is lambo murci pearl yellow
defintely not in the 40k neighborhood. If it was that cheap I would still keep it. Mirabile after building your car, you should know how much money I have in this car. Motor has 25K in it alone. Another 22K in the body. I ripped out the entire motor just to spray the engine bay. Also this car has some many rare parts. I am going to post the entire mod list soon, and it will be very long. Ha Ha
25K will the rebuild.
Here is the modlist
Exterior
- Repainted Lamborghini OEM Pearl Yellow Two Tone Black
- Veilside Fortune Widebody Kit
- Veilside Fortune Hood
- Veilside Fortune Front Bumper
- Veilside Fortune Carbon Fiber Headlight Buckets
- Veilside Fortune Rear Bumper
- Veilside Fortune Side Mirrors
- Veilside Fortune Rear Wing
- Veilside Fortune Carbon Fiber Front Lip
- Veilside Maijisty Crystal Emblems
- Vertical Doors Custom Lambo Door Kit
- Xenon Vision Custom 12000K HID Kit
- 99 Spec JDM taillights
- Carbon Innovation Carbon Fiber Door Handles
Interior
- Carbon Innovation Carbon Fiber Center Console
- Carbon Innovation Carbon Fiber Speed Cluster
- Carbon Innovation Carbon Fiber AC Panel
- Carbon Innovation Carbon Fiber Shifer Console
- Suede A Pillar
- Suede Headliner
- Suede Rear Hatch and Trunk Area
- Suede Shiftboot
- Suede Handbrake boot
- Cusco 8pt. roll cage
- Bride Vios III Seats
- Bride RX7 Seat Rails
- Sparco 6pt Racing Harness
- Sparco Suede Ring Steering Wheel
- NRG Quick Release Steering Wheel Kit
- Autometer Nexus Control Module
- Autometer Nexus Air/Fuel Wideband Gauge
- Autometer Nexus Fuel Pressure Gauge
- Autometer Nexus Boost Gauage
- Autometer Nexus Oil Temp Gauge
- Autometer EGT Gauge
- Autometer Water Temp Gauge
- Autometer Oil Pressure Gauge
Engine
- street port engine (Redline Engineering) 11k miles
- new 2 mm seals
- new rotor housings
- cryogenically treated engine seals
- lightened, clipped, and balanced rotors (Racing Beat)
- intake ports polished
- new pinned housings and other special machining for sand-rail motor (Redline Engineering)
Turbo
- HKS T04E single kit
- Greddy Front Mount Intercooler
- HKS SSBOV
- APEXi AVC-R Boost controller
- HKS air filter
Cooling
- Koyo Aluminum radiator
- Earl's 32 row oil cooler
- Unorthodox pulley set
Transmission/Drivetrain
- KAAZ 2-way LSD
- MazdaSpeed Power-Plant-Frame RARE
- B&M Short Shifter
- ACT street/strip clutch w/ extreme pressure plate
- Racing Beat 11 lb alum. flywheel
Fuel Management
- PowerFC computer tuned by XS Engineering w/ commander
- 660 cc pri, 1200 cc sec RC injectors (flowed and blueprinted)
- SX fuel pressure regulator
- Denso fuel pump
- Magnecor plug wires
- HKS iridium spark plugs
- B&M Newvolt Ignition Amp
- HKS Grounding System
Exhaust
- ceramic coated exhaust manifold,
- ceramic coated exhaust housing of turbo
- ceramic coated down-pipe
- HKS Carbon Fiber Titanium Exhaust
Suspension/Brakes/Wheels
- Rotora 6 Piston 14" Front Kit
- Rotora 4 Piston 13” Rear Kit
- New Mazda 929 brake master cylinder
- CWC sway-bar mounts
- Racing Beat front and rear sway bars
- Cusco front strut bar
- Tein Flex Coilovers
- Tein EDFC
In Car Electronics
- Pioneer Avic D1 Navigation Head Unit
- Custom Fiberglass Amp Rack
- Custom Fiberglass Sub Enclosure
- 2 Rockford Fosgate T152S POWER series 100 Watt RMS, 5.25” component system
- 2 Rockford Fosgate 2001bd POWER series AMP
- 1 Rockford Fosgate T18004 POWER series AMP
- 4 Rockford Fosgate T110D2 POWER series 10” woofer
- Lightning Audio AMP and Power Wires
- Optima Yellow Top Battery
- 2.5” Rear View Monitor
Here is the modlist
Exterior
Interior
- Suede A Pillar
- Suede Headliner
- Suede Shiftboot
Engine
- new 2 mm seals
Turbo
- HKS SSBOV
- HKS air filter
Cooling
- KAAZ 2-way LSD
- B&M Short Shifter
Fuel Management
- Denso fuel pump
Exhaust
- Tein EDFC
In Car Electronics
yooo that car very nice but u have all the money to do whatever you want an i just have to save up but so far i got the only full wide body kit in my state an its all my money no sponsors but i wouldnt mine getting some help hit me up with a pm ight peace
