dynoed 427whp with the gt35r...
Old 11-04-06, 04:51 PM
Rotor Nut.
got my fuel system finally working properly, and got a chance to put it on the dyno today. put down 427whp at 1.06 bar (15.4 psi). i was pretty impressed with the numbers, knock didnt got over 30. shell 93 pump gas was used. finished off at 425whp, cleaned up the afr's some more. here are the sheets.
Attached Thumbnails dynoed 427whp with the gt35r...-427-dyno-2.jpg   dynoed 427whp with the gt35r...-425-dyno-2.jpg
Old 11-04-06, 05:10 PM
Pettit Racing Posterboy
Bindon's Avatar
Wow. Nice numbers!
Old 11-04-06, 05:37 PM
Saiga-12 Power!
Juiceh's Avatar
I Like!
Old 11-04-06, 07:18 PM
matty's Avatar
damn thoise are nice numebrs car must be sick to drive! Who did the port?
Old 11-04-06, 08:08 PM
Bann3d. I got OWNED!!!
RX7 RAGE's Avatar
sweet
Old 11-04-06, 09:27 PM
bigcox_03's Avatar
what size port and turbo are you running?
Old 11-04-06, 09:35 PM
ALNY93R1's Avatar
Very nice numbers.
Old 11-04-06, 10:32 PM
Real nice #s for pump gas! This was a t4 I assume? What were your peak injector duty cycles?
Old 11-04-06, 10:40 PM
Rotor Nut.
no its a t3 1.06 a/r, short runner, open wastegate. the power came from the port work. it was done by lowe's performance in sarasota,fl. i dont think he is well known but he does great work. car idles great too. injector dutys were at 83%.
Old 11-04-06, 11:13 PM
Chasing numbers
sk8world's Avatar
lowes knows here stuff I was told awhile back. My dad bought a T-II off him 4-5 years ago. Also there is a local guy here in Huntsville , AL. "Van Cleef Racing" mostly Supras, but he uses Mike Lowe for any rotary rebuilds. Great numbers for pump and even better numbers than I woulkd have thought possible with a T3 and the short runners!! WOW!
Old 11-05-06, 12:12 AM
Big Daddy!!!
crazyrx7's Avatar
Nice. I'm glad every thing worked out for you.
R.K.
Old 11-05-06, 02:40 AM
Ding King
ROTARYFDTT's Avatar
congrats, what type of dyno?
Old 11-05-06, 02:44 AM
Ferrari Red Hotness
xblazinlv's Avatar
did you look @ the graphs?
It's a dynojet
Old 11-05-06, 02:59 AM
Ding King
ROTARYFDTT's Avatar
It's a dynojet
negative ghostrider.....time for sleep I think.
Old 11-05-06, 09:45 AM
600+rwhp club member
mr2foryou's Avatar
My friend Matt put down 410rwhp at 14.7psi on 93 octane with a long runner manifold and T3 35R with 1.06 hotside.
Nice numbers smg944. And very nice cars too.
Old 11-05-06, 10:06 AM
Nearing Completion...
str8ryd's Avatar
Was your friend also running a ported motor?
Back to topic: Those are great numbers. I really wouldn't have expected those from a T3 and especially on pump. Nice Job!!!
Old 11-05-06, 11:33 AM
boxed in and drawn out
APEXL8T's Avatar
Awsome,
now send me your IGL map!
Old 11-05-06, 11:43 AM
Speed Mach Go Go Go
GoRacer's Avatar
That's very impressive without the T4 and 500R wheel! I wonder how much of a difference 93oct 15.4lbs is compared to 91oct at 15lbs? Any pics or idea of how large the exteneded race ports are? Was it a Judge Ito template or his own port work?
Old 11-05-06, 03:23 PM
Rotor Nut.
i have pics of the ports. its tough to tell by the pics. the secret is a full port. not just opening the face hole. my port was all the way through. from where the intake manifold connects to the rotor opening. i had him port it and i built the motor myself with mazda 2mm seals.
btw here are some vids if anyone would like to see. they are on the top of the page. also the vids are 3rd gear which i was doing most of the tuning. the highest hp and final dynos were in 4th gear.
http://www.dropshots.com/smg944
Old 11-05-06, 05:25 PM
books's Avatar
Do you have SAE corrected numbers?
What was the ambient temp?
Old 11-05-06, 05:48 PM
Just in time to die
Zero R's Avatar
Guys those are good numbers for a ported 35R T3 setup, the T4's are getting roughly 10-12 hp more on average with better response. It just shows that when setup correctly you will see good results, and a lot can play into that. Credit to the builder!
-S-
Old 11-05-06, 06:42 PM
What shop was the dyno located at?
Old 11-05-06, 10:18 PM
Rotor Nut.
thanks to all the responces...
the ambient temp was 76*f with 5% humidity. it was actually 50* outside, but the dyno room is small so it heats up some. i was seeing 39-41c air temps. the dyno was located in MA, cd performance, he said steve kan had gone there a few years back to tune some rx7s.
Old 11-05-06, 11:35 PM
W. TX chirpin Monkey
fastrotaries's Avatar
what size exhaust? from ports all the way back. Great numbers,
Old 11-06-06, 07:22 AM
Rotor Nut.
3" exhaust all the way. i also have a racing beat dual tip. if i had an apexi n1 or something similar im sure i could have gotten a few more hp. but i like it quiet at normal driving.
Quick Reply: dynoed 427whp with the gt35r...
