Broken subframe, will solid engine mounts hold to the body shop if not driven?
Old 09-04-06 | 03:21 PM
KamakazieX's Avatar
the cross section (steering area) of the crossmember under the motor is chopped out. If I use my solid motor mounts, do you think that will be enough to hold the car together if its just going on a flatbed to be put on a frame machine?
Seems like it would do the trick so far but the car is still jacked on rails.
Need a body experts advice.
Old 09-04-06 | 03:34 PM
Madrx7racer's Avatar
what happened?
post pics
Old 09-04-06 | 07:15 PM
KamakazieX's Avatar
Heres all I got for a pic right now but it shows everything.
Trying to force the control arms back in, they have brand new bushings but I need something for the car to sit on until I can get it to a frame shop.
What I'm wondering is will the motor mounts hold the front end since they are solid just to make it on a flat bed to get on a frame machine.
Old 09-04-06 | 08:46 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
i wouldnt do that myself, and wouldnt reccomend that you do that either
myself, id weld any piece of steel i can find across the gap to get the car onto a flatbed, then once up there, id jack up the front of the car and set it on blocks for the ride over there
Old 09-04-06 | 08:57 PM
wildfc3s's Avatar
yeah i wouldnt advise it either do what kamakazieX said
Old 09-04-06 | 08:58 PM
I woudn't drive it like that........
Old 09-04-06 | 09:58 PM
KamakazieX's Avatar
I can't weld. What if I bolt a piece of steel to hold the gap together while the motor is jacked up to minimize flex?
Old 09-04-06 | 10:00 PM
Sure that would work
I just realized your in MA, where in MA maby i could help tommorow?
But yes, bolting some steel to it would deffinetly help. i myself wouldnt feel safe moving the car around with the subframe using the engine to keep its self relativly intact
Old 09-04-06 | 10:25 PM
KamakazieX's Avatar
Im in shrewsbury
Old 09-04-06 | 10:29 PM
mazdadude7's Avatar
"Expect Nothing"
I have a subframe if you dont already have one. if you need it pm me.
Old 09-04-06 | 10:33 PM
KamakazieX's Avatar
the studs are warped to bolt up a fresh crossmember, thats the whole issue. a friend of mine says he can realign the stud with a setaline. You think that would work or still have ******* issues?
Old 09-04-06 | 11:38 PM
KamakazieX's Avatar
So will bolting up a piece of steel cover me to the shop?
Old 09-05-06 | 06:25 PM
KamakazieX's Avatar
I'm kind of stumped, I cant just mig it right up, you think drilling whats left of the crossmember and bolting it with some grade 10 bolts and washers should hold good enough?
BNR34RB26DETT
42
02-28-18 12:27 PM
auggie463
21
09-02-15 02:46 PM
