Corksport ecu upgrade....???
FC Revolution
![](https://www.rx7club.com/images/misc/05_year_icon.png)
on
I am looking at my options as I set future goals for my car.
I wanted to know if a programed stock ecu for the FC3S, to higher boost like 12-14 psi, with the removed fuel cut, free flow exhaust and intake, stock turbo and intercooler, stock injectors. How much horse power would i expect. Would it be verry drivable/reliable.
I am looking into this option, because I won't be upgrading my car anytime soon, so I just want it to run right. I currently have a untuned A-pexi SAFC II, but want something that is tuned and ready. Short on money right now, so I just want to king of finish it of for now..
Has anyone used any of the corksport ecus?
I heard that you could call the guy that actually programs them for specific request, would it be chaper to buy it from the main guy, skiping the middle man?
I was thinking of this because I see a lot of "boost UP ecus" in ebay that range from 230 - 500 shipped, but used ecus are kind of risky speacially when the seller can't answer question like what size injectors was it tuned for and such.
![](http://www.corksport.com/store/image/f695/2rx-electronics/CORK_SPORT_ECU_Upgrade.jpg)
http://www.corksport.com/main.php3?p...3Fcat%3D273174
![](http://rhdjapan.com/images/ebaypics/May_3_to_June_3/5307REDOMECU/DSC00005.JPG)
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
![](http://www.jappartsspecialist.com/2120_RE_1989_FC3S_light_tuned_ECU_good_conditions_a.jpg)
Any thoghts, sugestions, or advice would be helpfull.
Gil
Gil
FC Revolution
on
So, i wrote an email to them.
"Hello
Thank you for your email. We can setup the ECU for you for the mods
you
have. For HP at that boost level I would expect 250 at the wheels.
Thanks
Derrick
At 10:29 AM 6/10/2005 -0700, you wrote:
>Date: Fri, 10 Jun 2005 02:33:45 -0700 (PDT)
>From: gildardo orozco <gildardo@blank.com>
>Subject: Just a question, ECU Upgrade
>To: inquiry@corksport.com
>I am looking at my options as I set the goals for my car.
>I wanted to know if you guys could program the FC3S stock computer to
exhaust
horse
>power would i expect. Would it be verry drivable.
anytime
A-pexi
>thank you for you reply....
>Gildardo Orozco
_________________________________________________
Cork Sport
3315 NE 112th #B-80
Vancouver, WA 98682
(360) 260 2675 Orders/Customer service
(360) 260 2676 Fax
(360) 260 2677 Tech Help Line
www.CorkSport.com"
250 WHP, is that true or possible.?
gil
"Hello
you
Thanks
Derrick
exhaust
horse
anytime
A-pexi
>Gildardo Orozco
Cork Sport
3315 NE 112th #B-80
Vancouver, WA 98682
(360) 260 2676 Fax
www.CorkSport.com"
gil
![](https://www.rx7club.com/images/misc/15_year_icon.png)
on
12-14 PSI on the stock turbo is a bit out of its efficeny(sp?) range youll be way over working it id am for more like 10-11 at the most with out doing nething else even that youll be taking a risk reliability wise and i think that 250WHP is a little stretch of the truth
i am legendary
From everything I've heard, 12-14 psi is about its limit, usually 13 is the highest you want to go. And it's not 10psi, I've read plenty of people doing 12 or 13.
FC Revolution
on
Kool, so 12-13 reliable. How much horsepower?
Gil
i am legendary
Power is variable depending on a lot of things, so I have no idea. But yah I'd stick with 12 psi, though I've seen a number of people do 13.
Still keeping the topmount doesnt seem like the best idea, though, because I think after like 10psi it just becomes an "interheater" heh.
Trending Topics
I'm running a tuned ECU with stock injection and a t04B turbo. I dyno'd tonight and made 285whp (had to turn the fuel pressure up to 35psi at idle to keep a 12:1 a/f ratio).
The ecu is made by a company in japan, but there is no label on my ecu box. I'll make copies for $100bux
CLIPPERNATION
on
that corksport ECU is $315, if you're SAFCII is already installed, why don't you get it tuned? it'll cost way cheaper than $300 and you said you were short on money
F**K THE SYSTEM!!
tuned ecus could have timing map remapped whick is VERY important when running above 8 psi. as for stock ecus dont have fuel nor timing maps above 8 psi(why fuel cut is important) So SAFC is nice for fuel but useless for higher boost.
