Rev Gauge - Problems??
Cheese
on
Of recent the stock rev gauge will occasionally drop to zero while the engine continues to run. It appears to happen when I change gears as the revs drop back to idle (roughly 800rpm) the needle drops to zero and then quickly recovers back to the correct rpm. The engine doesn’t stumble or do anything out of the usual so I can only assume the ECU continues to see the right rpm but the gauge does not. Has anyone had a similar problem? Does the input to the gauge come from the coils or ECU?
on
Yea... send it to cruisah@gmail.com, thanks!
Cheese
on
Originally Posted by Riccardo
There is a fix for this, by one of the forum members
I have done it, it works superb
I can send you the pdf file if you want
felixblack1(at)hotmail.com
3rd motors a charm I hope
on
send it to me too!! ajparent@syr.edu
Trending Topics
send it to me as well...i think i have it not sure....but any way..... IsLandboyL7@aol.com
