Other Engine Conversions - non V-8 Discussion of non-rotary engines, exc V-8's, in a car originally powered by a Rotary Engine.
RB25 powered FD Build!
Old 02-16-10, 06:56 AM
  #201
RB Power!
rXzach93fd's Avatar
yes it pulls extremely hard, I probably should get a stronger rear end. The first diff mount I had ripped right in half.
Old 02-16-10, 07:42 AM
  #202
Leeroy_25's Avatar
Looking forward to seeing some updates.. I presume if you had a chassis side loom from a donor skyline you could cut and splice the guage wiring for the FD into it to get it to work that way? How much is the wiring adapter going to set you back? I believe on the engine side the electrics are all a self contained loom. Was there anything you had to cut and shut into the ECU wiring so far? I am guessing the ignition/starter goes through that somewhere along the line and needing joining in?
Cheers
Lee
Old 02-16-10, 11:30 AM
  #203
RB Power!
rXzach93fd's Avatar
Cheers
Lee
Yea that might work. I think Im going to end up getting all autometer gauges that fit in the factory gauge spots.
The wiring was pretty easy I just spliced the skyline harness to the rx7s using pinouts.
I plan on getting rid of all the wires in the car and completely customizing it with new relays,fuses and everything.
yes, ignition wires are spliced in to each other
Old 02-16-10, 02:38 PM
  #204
Leeroy_25's Avatar
Cool. Any wiring pics you could pop up would be good?
That would be nice to rip all the old crap out and start fresh! At least you know where you are then!
Old 02-16-10, 05:59 PM
  #205
93' Rx7 Widebody
FlyinFINN's Avatar
Originally Posted by ByeByeSti
Just wondering; does the rb pull pretty hard in the fd??? im picking up my mounts, aluminum driveshaft+ a bunch of other parts for my swap this upcoming weekend. and also picking up my series 2 rb25 this weekend. pretty damn excited to start in on the swap
Not really. The engine doesn't make that much tq or hp. Your going to need to upgrade quite a few things to "pull hard".
Old 02-16-10, 06:02 PM
  #206
93' Rx7 Widebody
FlyinFINN's Avatar
Your rear end broke cause you made that abomination of a diff mount with no knowledge of how your rear end works AT ALL. Stock FD rear end will hold more than enough for what you have, the problem is your engineering.
Old 02-16-10, 06:03 PM
  #207
93' Rx7 Widebody
FlyinFINN's Avatar
Cheers
Lee
No, your Rotary tach is on a different pulse pattern than the i6. No amount of spicing will make it work. You need to get a box that can change pulse width or just get another gauge.
Old 02-16-10, 06:35 PM
  #208
RB Power!
rXzach93fd's Avatar
lol, we must have different ideas of pulling hard and what's a lot of torque. Im building a drift car and it has plenty of what I need.
Old 02-16-10, 06:54 PM
  #209
RB Power!
rXzach93fd's Avatar
I had a dumbass make all my old mounts and I knew it was a piece as soon as I seen it. It has all been corrected
I know very well how a differential works, there is no need to get so personal without knowing anything about me or the car. If you have a problem make a suggestion instead of an insult.
Old 02-17-10, 08:03 AM
  #210
Leeroy_25's Avatar
I second that.. No need to get personal. if you don't like the project get out the thread!
Thanks for the info on the tach though I presume you mean rev counter? assuming that runs of the crank sensors I can see how that might cause an issue.. So you need to fit a skyline rev counter then?! Or are such adapters an off the shelf thing?
Lee
Old 02-17-10, 10:37 PM
  #211
RB Power!
rXzach93fd's Avatar
Old 02-17-10, 10:38 PM
  #212
RB Power!
rXzach93fd's Avatar
Old 02-18-10, 02:12 AM
  #213
Jesse
R3AL.CH1CK3N's Avatar
nice build man.
Old 02-18-10, 05:49 AM
  #214
93' Rx7 Widebody
FlyinFINN's Avatar
Lee
How does what I said have anything to do with liking or disliking the thread? It has to do with him saying he needs a new rear end cause his "diff mount broke". Blaming Mazda engineers for not making a stronger rear end because your diff mount, that you said you had a dumbass make but you know how a diff works but you still put it on and tried it (which from one look anyone can see rebar diff mount bent into the shape of baloon animals and mounted all the COMPLETLEY wrong way, is a failure), makes no sense. You already copied my oil pan to a T, might as well copy everything else on my car including the diff mount, since it all had real thought put into it.
Old 02-18-10, 06:52 AM
  #215
RB Power!
rXzach93fd's Avatar
ill have pics of all the new mounts and everything when they get back from powdercoat.
I didn't say I needed a new rear end because the mount broke. The mount was on the car when I picked it up. I want a new diff because Ill eventually be pushing 400whp with my new turbo setup.
Yep, lol I copied your oil pan. Have you ever thought that since we have the same engine in our car, the way you have to cut the oil pan might turn out to look similar hmmm.....Im sure the old dirt track guy I sent the car to to make that oil pan came on the internet and stole your ideas...
Old 02-18-10, 07:56 AM
  #216
Leeroy_25's Avatar
FlyingFinn -
Reason is reading your posts sounds like you are coming all over with an attitude about the guy's build.. So what if it was all messed up first time.. I seem to remember in his early posts he said he was going to change it all once the car was up together. Not everyone can do a job perfect first time round ro has the facilities to do it.. But if they persist and get there in the end you should be giving them encouragement and advice along the way.. Especially seeing as you have the same swap? Why get pissy if his oil pan looks the same as yours. You should be flattered that someone has been inspired by your work if they had in fact copied it.
Anyway.. This isn't the school yard.. That's all I'm saying.. Enough already!
Lee
Old 02-18-10, 12:24 PM
  #217
RX-347
digitalsolo's Avatar
Paintwork looks good, glad to see this car coming around.
Old 02-18-10, 01:54 PM
  #218
Sabora's Avatar
Seems like an interestinf swap..even though i rather keep a ratary..a rotary..So i went with the 20b instead but i did give the rb25 a thought but i had no idea what i would be getting into if i had done it so good luck with the build it seems to be coming along quite well by the way nice paint..
Old 04-12-10, 09:22 PM
  #219
emperorbob5's Avatar
updates?
Old 04-15-10, 08:31 PM
  #220
RB Power!
rXzach93fd's Avatar
yea, sorry for the lack of updates. I have been busy with work and school.
I installed new black carpet and hooked the brakes back up with a deleted abs system.
Ill try to get pics up soon. I have been sand blasting and powdercoating the engine parts and there coming along very nice. Once I get them finished It should be smooth sailing!
Old 04-25-10, 10:54 PM
  #221
RB Power!
rXzach93fd's Avatar
here are a couple of pics of what I have been working on
my new garage
my powdercoating setup
getting close to getting her running again
Old 04-26-10, 08:44 PM
  #222
Dewayne
BB6 -2- FD3S's Avatar
looks clean
Old 04-29-10, 08:44 PM
  #223
ByeByeSti's Avatar
more updates now!! i wish i had some more info on this swap... i just got my oil pan and oil pick up set up done etc along with all sorts of other stuff. just need to figure out this wiring.... any help?? on what i can keep in there for the fuse box's etc i started to thin some stuff out already. now its time to wire it up. ive got a 94 touring edition and rb25det series 2
Old 05-07-10, 03:47 AM
  #224
Rx7 Wagon
Narfle's Avatar
Good choice of color
Old 05-07-10, 11:22 AM
  #225
Stage7's Avatar
very nice. clean. any more updates?
Quick Reply: RB25 powered FD Build!
