Tranny
Old 02-23-07, 05:46 PM
  #61
Sponsor
RX7Club Vendor
FDNewbie's Avatar
Oh yea...and that too
Old 02-23-07, 05:55 PM
  #62
Resident Know-it-All
patman's Avatar
i was under the impression that the supra getrag trannies were pretty rare and hard to find? Gt1-20B do you have a source for them that they would come with the kit, or would the buyer have to find one?
Old 02-23-07, 05:58 PM
  #63
Sponsor
RX7Club Vendor
FDNewbie's Avatar
Last I checked, they're still available new. And for those who would be getting the PPG gearset, there's no prob in buying a used blown one off of Supraforums
Old 02-23-07, 09:11 PM
  #64
Racing Rotary Since 1983
Howard Coleman's Avatar
93 supra TT ratios
1st---3.83--- really low unusable... supra had a 3.4 rear end
2nd---2.36--38% drop. from 7000 to 4319 rpm too much spacing
3rd--1.69---28% drop from 7000 to 5012. o k
4th--1.3----22% drop from 7000 to 5426 nice
5th--1----24% drop from 7000 to 5343 nice
6th--.79---21% drop from 7000 to 5530 nice but limits top speed to around 150 w 4.1 rear and there is no real low cruising mileage 6th.
how does the box shift at 7500+ rpm?
what is the weight of the box?
hc
Old 02-23-07, 10:25 PM
  #65
I'll blow it up real good
RX-Heven's Avatar
For an easy comparison....
Standard TII ratios:
3.483 / 2.015 / 1.391 / 1.1 / 0.719
PPG offerings for the Supra 6-speed gearbox:
3.20 / 2.19 / 1.56 / 1.20 / 1.00 / 0.83
Borg Warner 6sp T-56 Gear Ratios:
2.66 / 1.78 / 1.30 / 1.00 / 0.74 / 0.50
PPG ratios for the dog box conversion in a stock RX7 case:
2.527 / 1.805 / 1.381 / 1.155 / 1.000
And Gurus offerings for a dog box conversion in a stock RX-7 case...
Guru Circuit gear ratios:
2.387 / 1.705 / 1.339 / 1.444 / 1.0
Guru Targa gear ratios:
2.648 / 1.804 / 1.406 / 1.162 / 1.0
Old 02-23-07, 10:39 PM
  #66
RX-Heven's Avatar
If GT1-20b could answer this:
Are there dog-ring conversions available for this tranny?
I found one for the Gertrag V-160 6-speed offered by PPG. What is the differecne in case/internals design betweent the V-160 and W-160 versions or are there any?
I will be all over this if I can fit the PPG dog gears in the tranny he is doing the conversion for. Hell, I'll be first in line for that matter by placing a pre-order as this is EXACTLY what I have wanted and been hoping for all along.
Old 02-23-07, 11:09 PM
  #67
GT1-20b's Avatar
I found one for the Gertrag V-160 6-speed offered by PPG. What is the differecne in case/internals design betweent the V and W versions?
http://www.powerhouseracing.com/file...ine%20Upgrades
Stand corrected.
The correct Getrag designation IS V-160
Apologies for the Typo error.
Thank You.
Now, I'll try to answer some questions ...
This gearbox is Type Specific to the Toyota Supra TT. meaning it was specifically designed for that car, that engine.
The 2Jz. Therefore the bellhousing is NOT detachable or removable.
The bellhousing is part of the main case. So you must convert the engine to gearbox bolt patern to that which the boxe's bellhousing will accept.
The "Kit's" adaptor plate, adopts and places the bolt pattern of the 2Jz onto the Mazda, so the Supra's TT gearbox just " SLIPS ON ".
A dedicated Tilton style Reverse Rotation Super Starter is then installed in the hole were originaly the Supra's clutch release slave cylinder would normally go.
The box is crossectionally bulkier, but substantially shorter than the FD's.
This will be illustraded in a side-by-side comparison when the pics. are uploaded.
Stock, this gearbox is capable of handling well over 1000 HP, corresponding monster torque, with sure & lightning fast shifts.
The shifter sits in a tripod base separate from the main case.
Theoretically, one could place the shifter as close or as far away as nesesarry.
No forward access cover provided or nesesarry.
The box is stronger, lighter, and physicaly smaller (more compact) than a T-56.
The Kit's ancillary components, ie: Clutch, Flywheel, Release bearing, ect. are all
"off the shelf " components.
The phylosophy of design was based around the use of readily available proven name brand pieces and components.
Street: Tilton 8.5 Dual Disc OT series on either Aluminum or Steel Flywheels, w/ 750 Lbs/Ft. torque holding capasity.
Race: compatible with any 7.25 or 5" inch 2, 3, 4, disc, or Carbon/Carbon clutch pacage.
Racing: several vendors offer Dog ring engagement close ratio gear sets for this box. ie: the PPG as previously mentioned.
Ryan mentiones: the " USELESS " 1st. gear, and shorter top gear than FD's
This is partly true but NOT correct. Depends on use and intended purpose
This box as used in the Supra, was combined w/ a 3.13 Ring & Pinion final drive.
As oposed to the FD's Standard 4.10 or 3.90 for the Auto's.
As a Street racer and weekend Drag warrior, the gears are perfect for hard launches, best acceleration, and great ET. 6th. gear, not 1st. then becones useless as it will never be used in that senario.
As a Track day car, again the very close grear drops combine w/ the FD's final drive provide for excelent ratios for ANY track.
In this senareo 1st gear would not be used except for pit row.
Even with this low 4.10 final drive, asuning a 26.5" diameter of an average 17" wheel & tire, at 8200 Rpm in top gear if ther is enough power to get to that RPM, it equates to 198.99 MPH.
With the Auto's 3.90 now we're talking 209.30 MPH.
I wonder how many of us have the COJONES to drive our "street cars" that fast ?
I know I don't !, ...and as most of you know, I drive and have driven some pretty fast racecars.
Now, If Non-Real world Hypothetical numbers game turns on your fancy, and Theoretical MPH #'s is what you'r after, do as the V-8 guys do, install a Cobra 8.8 IRS Diff, pick the terminal speed you want from a wish list, do the math and
install the gear that will get you there. ...v For example:
A common Ford final gear like a 3.08 X a top gear of .793 as in the Supra box's top 6th gear at say 8000 Rpm. with the same 26.5" rear tire diameter.
That will yield a top speed of 258.59 MPH. WOW,
This is absolutly unreal and imposible but in theoretical terms ?? what the heck !.
As for a price, I don't have one figured out as yet.
But I know it will be substantially cheaper that a complete T-56 convertion.
For now it will be on a per order basis.
I have built enough parts for 3 Kits besides my own.
Who knows, if enough interest is generetad, maybe a GP can be arranged.
If interested or have specific questions, PM me.
Thanks
GT1-20b
Old 02-23-07, 11:24 PM
  #68
RX-Heven's Avatar
I got first dibs on one of them you have available.
pm me any deposit info
Old 02-23-07, 11:28 PM
  #69
Sponsor
RX7Club Vendor
FDNewbie's Avatar
If everything works out as previously described, I'm 2nd in line.
Old 02-23-07, 11:32 PM
  #70
Needs more cow bell
Doc Holiday's Avatar
Why not just throw a Richmond box behind it? Seems like it would cost a lot less.
Old 02-23-07, 11:39 PM
  #71
mirabile's Avatar
Group Buy Group Buy Group Buy
Old 02-23-07, 11:43 PM
  #72
GT1-20b's Avatar
True, would cost less.
But not as elegant or presice
Plus the external shift rods to constantly deal with.
Old 02-23-07, 11:52 PM
  #73
Sponsor
RX7Club Vendor
FDNewbie's Avatar
https://www.rx7club.com/showpost.php...5&postcount=12 They have a very low torque rating. Useless IMO.
Old 02-24-07, 08:22 AM
  #74
Glutton for Punishment
IronMdnX's Avatar
Just saw this update.
Very interested, Looking forward for pictures and more info.
Old 02-24-07, 09:36 AM
  #75
re the supra trans.
since the bellhousing must be supra it will be important that it is not too bulky for some.
i run two 3 inch downpipes and the FD bellhousing works just right in relation to the tunnel. should the supra bellhousing be larger i would have a problem and would not hack up the tunnel to fix it.
i understand that others might not have the problem and of course you would have lots more latitude if you are running a dedicated racecar or if you run a 20b and have it moved back a bit.
i do agree w Carlos that if you ran the cobra rear and had a wide array of rear axle ratios that the overall gearing w regard to trans ratios could be worked out... and we each could pick what would work according to our needs.
i am planning on running the Silver State Classic so i need a bit of legs to my final drive ratio and it could be done w, say, a 3.12 and turn 4th into a 1 to 1.
howard coleman
Quick Reply: Tranny
