Bad Front Sway Bar?
Old Jul 23, 2008 | 04:24 PM
oo7arkman's Avatar
In the Garage
Bad Front Sway Bar?
While changing out my old worn-out stock strut assemblys for my new coilovers I noticed something that bothered me a bit. I neglected to unbolt the front sway bar before trying to remove the stock assembly (I was in too big of a hurry). To my surprise, the hub almost lowered enough for the strut assembly to come out. I unbolted the sway and finished the driver's side. Then, just to check, I bolted the sway back up and tried to do the same on the passenger side... No luck. The sway bar held the hub a good 5inches or so higher than it had on the driver's side. Sounds like the sway bar is messed up and needs replaced. Any thoughts??
matty
12
Jan 18, 2020 10:39 AM
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
need RX7
11
Aug 19, 2015 08:27 AM
