Top mount starter for 13b motorcycle
Old May 16, 2012 | 07:13 PM
gerald m's Avatar
Dragons' Breath
Just wondering if it is possible to do a change over from the bottom mount starter on a 86 gsl 13b to a top mount without major changes and if so are they or can they be a good set up .
Reason for wanting to change over is the bottom mount starter tends to stick out a bit more than I would like . Also being out that far on a cross mount setup tends to make the bike center of gravity to far off ..
Everything seems to balance out nice with the starter sitting on top. Thanks Gerald m.
Old May 16, 2012 | 09:17 PM
Qingdao's Avatar
HeyHeyHey..Its the Goose
Wait... You have a 13B in a motorbike?
HD frame and transmisson?
Sorry if I am off topic.
Old May 16, 2012 | 09:48 PM
flight_of_pain's Avatar
its supposed to do that
Some of the early rotaries (-pre '78) had top mount starters, that's what the odd cutout above the oil filter pedestal is for, they kept it in the castings.
Isaac
Old May 16, 2012 | 10:26 PM
DivinDriver's Avatar
1st-Class Engine Janitor
Old May 16, 2012 | 11:20 PM
DreamInRotary's Avatar
Always Wanting to Learn
Ahaha ^ I agree completely, I clicked on the thread just to see pictures!
Old May 16, 2012 | 11:32 PM
gerald m's Avatar
Dragons' Breath
[QUOTE=DivinDriver;11093315][/QUOT[
Your not berry nice .Having a bad day maybe . ( Pictures we don't need no stinkin pictures ) But I do have a video if you really want to take time to watch it . .the whole thing I speak of is in this one nice little song there too , She's a hottie maybe that will cheer you up if not I got a couple phone numbers for ya .. http://www.youtube.com/watch?feature...&v=hcjib6q3cAE
Be nice it's easy , have a good one Gerald m.
Old May 16, 2012 | 11:43 PM
gerald m's Avatar
Dragons' Breath
No your not off topic not to far anyway .. I suppose you want pictures too well here's two years worth https://www.rx7club.com/old-school-other-rotary-63/bike-dirt-drags-13b-na-936752/ enjoy I'm the boy that builds the boat and I'm the boy that sails her .
Old May 16, 2012 | 11:49 PM
gerald m's Avatar
Dragons' Breath
https://www.rx7club.com/showthread.php?t=936752
there's two years worth for you too. Have a good one
Old May 17, 2012 | 09:53 AM
I'm plenty nice... I just want me some pictures.
"Dragon's Breath;" nice!
Old May 17, 2012 | 02:12 PM
DerrickS's Avatar
His name is spot
Originally Posted by gerald m
No your not off topic not to far anyway .. I suppose you want pictures too well here's two years worth https://www.rx7club.com/showthread.php?t=936752 enjoy I'm the boy that builds the boat and I'm the boy that sails her .
Ahhh Canadian drinking songs! But you gotta pronounce "boy" as "by".
sorry... I got a Newfie friend.
Old May 17, 2012 | 05:27 PM
gerald m's Avatar
Dragons' Breath
That's Stompin Tom's song .. Hey what's with those guys anyway the only time they admit to being a newfie is when there drunk or wwwhatever . In know a few of them , if your with more than one at a time it is almost overwhelming .
And I'm the BY that catches the fish and sends em home to Lizer
Old May 18, 2012 | 12:02 PM
Too many Newfie jokes out there... Makes 'em shy unless they are in groups.
I live in SoCal and even I've heard of Newfie jokes.
Old May 18, 2012 | 12:11 PM
Directfreak's Avatar
I am a Jeeper Now.
That intake looks nice, but with the Carb on it, doesn't it interfere with something? Seems very tall.
Also, a two barrel Holley is going to perform very poorly on a 13B. Simply not enough air and fuel.
Perhaps you could go with Fuel Injection and save alot of room, and make much more power?
Congrats on the build so far.
Old May 19, 2012 | 09:32 AM
gerald m's Avatar
Dragons' Breath
The carb is a little high but the engine is very low so no it won't be a bother .As far as volume I have changed everything inside , there are no jets left power valve is blocked and there has been an enriching kit installed , check out carb enriching kit in my videos . According to the charts of air volume and air flow it should work fine . for a stock engine. This setup up has been used in the aircraft industry where guys are building their own light aircraft . It is a trial so we will see how it works ,, There will be no top tube for the frame so everything is open at the top , engine comes straight out the top .. Yes I have stated more than once that next build will be injection . But what about the top mount starter I can't believe how little the community knows about the subject ?? Thanks for the input Gerald m.
Old May 19, 2012 | 01:50 PM
Jeff20B's Avatar
Lapping = Fapping
Not even I know about top mount starters, unless it's for the old twin dizzy 12A, which has a ring gear that is about 10mm forward or rearward of all 74 and later flywheels (can't recall which direction but remember it makes it incompatible). So I'd ask Atkins since they do top mounted starters on 74 and later engines for boats and what not. Also some race cars back in the 80s had small top mount starters. j9fd3s may have seen some.
Old May 19, 2012 | 05:17 PM
bwaits's Avatar
Needs More Noise
I have had a few top mount setups. I still have a 4 speed gearbox with top mount starter (bell housing is removable like the later turbo models). The starters were very large and heavy. The automatic transmission starters were the heaviest of the two as the field coils were larger so they spun faster.
Old May 19, 2012 | 06:51 PM
gerald m's Avatar
Dragons' Breath
Interesting , Well i would like to stay as light as possible but a couple pounds extra would be worth it .
So either starter will work for the same application ? would it work with my auto trans flywheel If I put a taper on the back side of the teeth ? I would buy one from a forum member but maybe napa could get one , by the time I pay shipping I could put the extra into a new guy . Even the bottom mount are different between auto and standard ( brushes anyway ) .. Thanks for your time and input Gerald m.
CaptainKRM
14
Aug 26, 2015 09:52 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
